B16 cable tranny
Old Jan 17, 2006 | 03:52 PM
SupraRXZ's Avatar
Default B16 cable tranny
Which year should i use for my motor because I need to no how many splines or sumthing like that. I have a 99 LS motor with a GSR flywheel and stage 1 ACT clutch and i was wondering which year b16 tranny do I need for my car
I really need to no ASAP
thanks
Old Jan 17, 2006 | 06:02 PM
jdmcars.com's Avatar
Default Re: B16 cable tranny (SupraRXZ)
Any B Series will bolt up to the 99, but what year car do you have?
Old Jan 17, 2006 | 06:41 PM
SupraRXZ's Avatar
Default Re: B16 cable tranny (jdmcars.com)
i have a 90 civic hatch
Old Jan 17, 2006 | 07:25 PM
Ok. You need a B Series Cable transmission.
You can use a J1, S1, Y1 or A1. They have different gear ratios, so it depends on what you are looking for with the car of what might be best.
The YS1 is a cable trans, has a different spline count than the ones above, but can be used.
If you are looking to re-use the clutch that is is on the 99 engine all ready, that would only be the YS1 cable trans that will work that is cable.
If you get another clutch, you can use the J1, S1, Y1 or A1 tranny.
Old Jan 18, 2006 | 12:52 AM
SupraRXZ's Avatar
ok so as long as i get a jdm b16 cable tranny I can still use my ACT stage 1 clutch from the LS tranny?
Old Jan 18, 2006 | 02:44 AM
rainforest's Avatar
no you would need a 91-92 ls or 92-93 integra gsr cable tranny. the latter of the 2 is the ys1
Old Jan 18, 2006 | 12:11 PM
SupraRXZ's Avatar
Default Re: B16 cable tranny (rainforest)
but arnt there b16 ys1's? because I want shorter gear ratios too
ever'sneighborhood
20
Jul 26, 2011 11:51 AM
NewEra
Jul 24, 2009 06:38 PM
efcivic12
Nov 8, 2008 07:40 AM
civicandy
Sep 1, 2006 11:26 AM
hotimportcrx
Aug 24, 2005 06:31 AM
