D-Series Pistons
D-Series Pistons
Since I have the opportunity to do some rebuilding on my motor I figure why not try to get a little more power out of my little single cam? So what I'm wondering is, is there OEM honda pistons that can be put in place of my D16Y8 pistons to up the compression? I'm really looking for ones that I won't have to bore the cylinders so I can keep the snappy response I have now, but if needed I will go just a little bit over. I'm also wondering how far I can mill the head to up the compression just a little more? Somebody help me here I need to get my car back ASAP!
So the D16A1 pistons are for high compression? What kind of numbers am I looking at here? I'm wanting to mill the head a little bit to up the compression a bit more...I'm looking to go between 10:1 and 11:1, do you know how far I would have to mill the head to reach that ratio?
I have to say that is one bad *** calculator! I do like that the pistons give 13.1:1 compression but thats WAY too high for what I'm going for. I found that using the D16A6 pistons will give me the ratio I'm looking for! Thanks for the help guys!
cincyb20ek
07-12-2010 06:31 PM
fdjizm
12-10-2006 10:04 AM
