which of these wires is the knock sensor? gsr swap in 92-95
also which one is the iab and evap purge, i did a gsr swap on my 94 coupe ran the vtec wires to A4 and D6 thats working good now just need the other 2 thx in advance
Re: which of these wires is the knock sensor? gsr swap in 92-95 (screen_name)
the knock sensor is a red/blue wire thats in the middle plug(10 pin plug) on the passenger side shock tower connector that goes to D3. Evap is a red wire. If you using a GSR harness, it will go to the bottome plug on the passenger side. IF you using an LS or civic harness it goes to the driverside plug. EVAP wire goes to A20. IAB is a pink/blue wire. IF your using a GSR engine harness it goes to the drivers side connector. I Would just cut the wire near the sensor and run it over to the passengerside and to the ecu at A17.
CrazyHB
08-30-2004 06:51 PM
