crvtec vs h22
Old Jan 8, 2006 | 07:33 PM
doodooheadfart's Avatar
Default crvtec vs h22
sorry
im a noob
ive been browsing topics alot
but which one would be the easier install and the better daily driver
once again
sorry (noob)
Old Jan 9, 2006 | 05:12 AM
killer hatch's Avatar
Default Re: crvtec vs h22 (doodooheadfart)
it really all depends on you. they are pretty much the same when it comes to instalation. the b20 is a little easier but not much. me personally i'd go h22. not just cuz i got one in my hatch but i've seen what both do. have fun.
Old Jan 9, 2006 | 07:20 AM
IHateJDM's Avatar
Default Re: crvtec vs h22 (killer hatch)
b20 is the easier swap. they are both equally reliable as DD's (depends on the driver more than the motor).
Old Jan 9, 2006 | 08:35 AM
Honda Bull's Avatar
Default Re: crvtec vs h22 (IHateJDM)
B20VTEC.... you'll most likely have to build it. Unless you find someone who has built one and is selling.
H22.... comes put together from Honda.
If you're not mechanically inclined, or have someone who is, I'd go H22. Even if you were I still would. But. That's my opinion.
Good luck with it though.
Old Jan 9, 2006 | 05:26 PM
Default Re: crvtec vs h22 (Honda Bull)
i dont mind building it up
i would actually enjoy it
which one would be more reliable and more power is what i should be asking
and im planning on going turbo which i heard works well on either one
Old Jan 10, 2006 | 05:58 AM
happyb16xrc's Avatar
if its going in the sedan than i would go h22, you are going to need some power to push 4 drs
Old Jan 10, 2006 | 06:12 AM
IHateJDM's Avatar
if you end up slapping a turbo on a b20, it would be a good idea to sleeve it.
Old Jan 10, 2006 | 07:35 AM
Honda Bull's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">if you end up slapping a turbo on a b20, it would be a good idea to sleeve it. </TD></TR></TABLE>
It would probably be best to sleeve either if boosting. But not entirely necessary for the H22 under 10 lbs or so.
Old Jan 10, 2006 | 07:46 AM
AudioFuct's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doodooheadfart &raquo;</TD></TR><TR><TD CLASS="quote">which one would be more reliable and more power is what i should be asking and im planning on going turbo which i heard works well on either one</TD></TR></TABLE>
More reliable out of the box would be h22 hands down. You dont have anywhere near as many things to do to the motor itself to have your car up and running and on the road. As for power......... rofl...... crvtec aint nothing special when its done.
You're seriously talkin apples and oranges when you're talkin about these two motors. They couldnt be any more different.
Old Jan 10, 2006 | 03:58 PM
Default Re: crvtec vs h22 (AudioFuct)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AudioFuct &raquo;</TD></TR><TR><TD CLASS="quote">
i heard that the crvtec has ALOT of power and ALOT of torque
so what are the main power differences between the two motors
and
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by happyb16xrc &raquo;</TD></TR><TR><TD CLASS="quote">if its going in the sedan than i would go h22, you are going to need some power to push 4 drs</TD></TR></TABLE>
hows it have more power if its going into a 4 door
i do have a sedan but i thought that the crvtec had more torque
sorry im just really really confused
Old Jan 10, 2006 | 08:16 PM
AudioFuct's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doodooheadfart &raquo;</TD></TR><TR><TD CLASS="quote">i heard that the crvtec has ALOT of power and ALOT of torque
Well, i cant speak from experience, as ive never owned a crvtec, I also cant say they are ALL the same. But, I can tell you we had a guy locally with a crvtec setup, lots of bolt ons (IM, Header, built head.... lotsa ****) and he put down 167whp. I had a h22 in my coupe. I had CAI and a chipped p28 running chrome, so i was tuned, and i put down 191whp..........
So, you figure it out. I put down 191 with pretty much no mods, and he put down 167whp with all that crap. Now, granted he wasnt tuned, but.... even so..... 167whp? pfft.... no thanks. All that work and **** to show for it. I'll take an h22 over a crvtec any day.
Old Jan 11, 2006 | 04:10 AM
Specail Ed's Avatar
Boost the H22.
Old Jan 11, 2006 | 05:19 AM
IHateJDM's Avatar
sorry im just really really confused </TD></TR></TABLE>
he means you'll need more power to pull the 4 door since its heavier than a coupe or hatch. don't worry about it though, either motor will pull it just fine.
Old Jan 11, 2006 | 05:45 AM
RotiEatter's Avatar
Ditto
H22A is the only way to go.
You'll run 14s and get close to 30mpg.
Old Jan 11, 2006 | 06:04 AM
high_revs's Avatar
Default Re: (RotiEatter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotiEatter &raquo;</TD></TR><TR><TD CLASS="quote">H22A is the only way to go.
You'll run 14s and get close to 30mpg. </TD></TR></TABLE>
word, i get 30mpg with my h23/vtec 345cc injectors and a 255 walbro turbo pump untuned and can go to the track and run a low 13
Old Jan 11, 2006 | 06:36 AM
ALMXDUPINTEGRA's Avatar
ditto
Old Jan 11, 2006 | 06:41 AM
Default Re: (SB tuning)
i went head to head with a semi built b20 on the freeway and it didnt impress me. all i had done to my motor at the time was jasma headers, str fuel rail, spoon exhaust with 2.5 piping (no cat) quife diff. and a cluitmaster stage three clutch with a lightened flywheel. he had pretty much everything done except turbo. like i said it did nothing to impress me. we started off with a 3rd gear 50 mph pull and the minute my vtec cracked i was gone. you cant go wrong with the h22 its strong right out the box.
Old Jan 11, 2006 | 01:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SB tuning &raquo;</TD></TR><TR><TD CLASS="quote">word, i get 30mpg with my h23/vtec 345cc injectors and a 255 walbro turbo pump untuned and can go to the track and run a low 13 </TD></TR></TABLE>
wow
and ive been looking at H22's and they're quite expensive ( about 3 grand)
and i heard that they are harder to install and that they weigh about 200 pounds more than a b series
Old Jan 11, 2006 | 01:52 PM
IHateJDM's Avatar
Default Re: (doodooheadfart)
wow
and i heard that they are harder to install and that they weigh about 200 pounds more than a b series</TD></TR></TABLE>
3 grand is a lot for an H swap, they are harder to install, but only weigh 50 lbs or so more than a b series. There is a lot of bs floating around about that swap, so don't believe everything you hear.
Old Jan 12, 2006 | 06:28 PM
Default Re: (IHateJDM)
who has swaped it into a civic?
how hard was it?
whered you buy your motor?
and how pleased are you?
lol
Old Jan 12, 2006 | 07:18 PM
AudioFuct's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doodooheadfart &raquo;</TD></TR><TR><TD CLASS="quote">who has swaped it into a civic?
how hard was it?
lol</TD></TR></TABLE>
are you asking about the h22 swap? If so............ you get a slap in the forehead for even asking BEFORE searching.........
Old Jan 13, 2006 | 06:05 AM
RotiEatter's Avatar
Ditto
Default Re: (killer hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killer hatch &raquo;</TD></TR><TR><TD CLASS="quote">i went head to head with a semi built b20 on the freeway and it didnt impress me. all i had done to my motor at the time was jasma headers, str fuel rail, spoon exhaust with 2.5 piping (no cat) quife diff. and a cluitmaster stage three clutch with a lightened flywheel. he had pretty much everything done except turbo. like i said it did nothing to impress me. we started off with a 3rd gear 50 mph pull and the minute my vtec cracked i was gone. you cant go wrong with the h22 its strong right out the box. </TD></TR></TABLE>
Everything, but turbo? So was it built low compression for a turbo?
Or did you mean he had I/H/E?
how hard was it?
Into a Civic?!? Damn, I thought we were talking about Preludes. Don't do it into a Civic, the H22A weighs like 300 pounds!!!!
I did the H22A swap into a 2001 Prelude and it took me 36 hours total. I had 3 ASE techs and we did it in a real garage.
We bought the motor from some Laotian kid that sells stolen motors out of the back off a van. He didn't have a H22A in the van though, only ITR and K20 motors. So we had to drive a hour to his house and he had a few strippped Preludes in his backyard. We ended up pulling out our own H22A from a 2000 Prelude.
I was pretty pleased with the motor because it came with some sweet **** like an Weapon R cold air intake, Nology spark plug wires, and a chrome oil cap. Can't complain about that kinda sweet **** .
I would never put it into a Civic though; there is just toooo much weight.
Old Jan 13, 2006 | 11:15 AM
[Everything, but turbo? So was it built low compression for a turbo?
high compression. full skunk 2 valve train, aeris pistons, dc 4-2-1 headers. venem fuel rail, a hurricane or tornado something intake manifold. skunk two stage to cams and cam gears. biger injectors (not sure on size) holly fuel pump. their were some other **** in their. the point is i wasnt impressed. it was a monster in a quarter mile but just wasnt impressing me on freeway runs. thats what i like. high speed, i love it.
Old Jan 13, 2006 | 11:22 AM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killer hatch &raquo;</TD></TR><TR><TD CLASS="quote">i went head to head with a semi built b20 on the freeway and it didnt impress me. </TD></TR></TABLE>
that's semi-built to you? sounds like he did everything but bore and sleeve the block. You also can't just slap a turbo on that setup. Not that it matters, he was lying to you about what he had. If he had that much work done he would have walked you from 50.
Old Jan 13, 2006 | 05:00 PM
i helped build the motor so i know what i was up against. it probably had to do with the way it was tuned. he is one of those guys that just doesnt listen to people. he use to work with the venem race team and he thinks he is dr.honda himself. he liked drag racing so he had the vtec cracking at like 4k. like i said he was a monster in a quarter mile that is till some jack *** in a mitsibitchy evo8 pulled out in front of him at 115mph. all i was saying with the way i like runnig (freeway) i just wasnt into it. like i said earlier its all preferance and building.
