what T-belt to use with a b18c block and ctr head ?
1 Post
I was with my friend today trying to finish his motor and when we came to the part where we need to install the t-bel ,, itididn fit ... this was a brand new gsr t belt ...
motor is a b18c1 with a ctr head
THANKS IN ADVANCE
THANKS IN ADVANCE
1 Post
Re: what T-belt to use with a b18c block and ctr head ? (PURPLETERROR aka BIGMATT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR aka BIGMATT »</TD></TR><TR><TD CLASS="quote">your doing something wrong</TD></TR></TABLE>
huh?
huh?
Re: what T-belt to use with a b18c block and ctr head ? (EGSR)
he is saying make sure you are tensioning the belt correctly. Because the gsr is the right belt. Due to the fact the you are using a gsr block and the head is the same height as a gsr. whats the part number of the belt? or is it reused?
1 Post
Re: what T-belt to use with a b18c block and ctr head ? (ProJectCvic)
well he told me that he order it from passwordjdm and yea I did look for that p72 part number , bc I know all gsr parts are p72 so I was looking for it but what I only saw was pt3 or pr3 or something like that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGSR »</TD></TR><TR><TD CLASS="quote">well he told me that he order it from passwordjdm and yea I did look for that p72 part number , bc I know all gsr parts are p72 so I was looking for it but what I only saw was pt3 or pr3 or something like that
You need to look at it again. If it does say pr3 you have the wrong timing belt. You need to go to acura and order this part number....14400-P72-014
Re: what T-belt to use with a b18c block and ctr head ? (BigBlockH22atch)
did u loosen the tensioner first? if it hasnt been loosened, u'll never get that thing on.
1 Post
Re: what T-belt to use with a b18c block and ctr head ? (thapimpfromchi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thapimpfromchi »</TD></TR><TR><TD CLASS="quote">did u loosen the tensioner first? if it hasnt been loosened, u'll never get that thing on. </TD></TR></TABLE>
pufff ... I loose all the way out and nothing
oh alright, well, try this one out. which motors water pump r u using? the b18, or did u go with the v-tec water pump too?
Re: what T-belt to use with a b18c block and ctr head ? (91B16HF)
If you bought a pr3 belt from honda or acura you are pretty much stuck with it. I have never been able to get them to take a return from me. Check the price on a b16 water pump versus a gsr timing belt and just buy the cheaper of the two.
loverboy
10-01-2007 10:22 PM
Civic44
08-03-2004 11:53 AM
