H22 mounts that allow a/c and p/s!!
hey guys,
I was bored and looking at random stuff. Supposedly this guy is selling a mount kit from Spark Racing in Southern Cali that allows you to bolt in an H-series and keep a/c and p/s. Has anyone heard of this before? Thanks. Oh yeah, here's the link:
http://www.thepartstrader.com/Single...=130&C2ID=1004
Re: H22 mounts that allow a/c and p/s!! (HatchMan)
if this is into an eg chasis, then A/C and P/S can be done with a lude swap. The only mount kit i know of that will allow you to do this is the hasport kit. If this is for an EK then I don't know. Also, i have never heard of that company. Later
edit: After some more research, I see that Hasport has now released the mount kits for the EK's. So A/C and P/S can be retained in Ek's as well. Later
[Modified by SilverCivic2k, 9:52 PM 1/12/2003]
for power steering in an eg chassis with the h22a, you will have to fabricate the radiator support for the pump. as for the power steering line, you will have to get a custom line, as there is EXTREMELY little clearance between the driver side of the h22 and the driver shock tower. (the crank pulley and alternator barely even clear)
as for A/C, that goes under the Alternator and there is enough clearance for A/C with H22 in an EG chassis...
as for EK/DC chassis, the engine bays are slightly bigger and will work. You have to get a 97+ prelude power steering line I believe, and same applies with A/C...they will work and HCP makes an A/C bracket for that.
And FINALLY hasport comes out with EK h22 mounts damnit.
UpstateCivic
59
05-11-2003 12:01 PM
