B18B1 into a 87 civ body...clutch problems
Having problems with mounting the hyd. clutch master cyl......no room.... brake booster in the way.. Is there a cable operated trans that would work in this swap , making it much easier.
Re: B18B1 into a 87 civ body...clutch problems (ArinX)
yes, although i am revising, i have a crvtec with s1 tranny from 91 jdm b16 in 87 rex si. most will tell you this is the way to go.
Re: B18B1 into a 87 civ body...clutch problems (VTECVillain)
One more question ...what aboutt axles ..is there a easy swap, havn't found any as of yet... Thanks for the help..any insight would be appreciated.
