Distributor compatability question
Old Jan 14, 2003 | 12:20 PM
Soled Out's Avatar
Default Distributor compatability question
I got a JDM b16a II, and the distributor keeps on eating up distributor caps and rotor buttons, so im under the assumption that i need a new distributor. So here lays the question. Can i put the distributor off my original 93 cx motor onto the b16a? I know the rotor cap and button are same from the two, but what about the whole distributor assembly? Hondaautomotiveparts.com reads 8000$ for a new distributor and im not about to pay that!
Old Jan 14, 2003 | 12:23 PM
sivik2nr's Avatar
Default Re: Distributor compatability question (Gray EG on Jack Stands)
$8000?!?!? ~~ do you mean $800
Old Jan 14, 2003 | 12:27 PM
Soled Out's Avatar
Default Re: Distributor compatability question (sivik2nr)
Maybe its a typo, but it says 8000, even at 800 i still wouldnt buy one
But can someone tell me if i can use my cx distributor on this, and if not tell me why it wont work, thanx
Old Jan 14, 2003 | 02:01 PM
JDM EG2's Avatar
You can take all the guts out of the 93 civic distributor and put it in your dohc distributor. Only thing you have to reuse is the case and shaft from the dohc distributor.
