obd1 harness and distributor ?
Old Jan 6, 2003 | 11:35 AM
GReddy SI's Avatar
Default obd1 harness and distributor ?
obd1 it is then, now my question is could i use my stock vx harness and distributor from my vx? and get my stock vx ecu chipped, or get a p30 or p28, i talked to this guy at a shop he told me to get a 91 crx si harness and get a 91 crx si distributor, and get a p30 or p28 ecu could that work?
Old Jan 6, 2003 | 11:53 AM
jmm96gsr's Avatar
Default Re: obd1 harness and distributor ? (GReddy SI)
what engine are u talking about and what car???????????????
Old Jan 6, 2003 | 01:02 PM
Kataku2K3's Avatar
Default Re: obd1 harness and distributor ? (jmm96gsr)
Definately need to know that... OBD1/2 and non OBD ECU's and distributors are not interchangable... Injectors are interchangable but say if you wanted to run an OBD1/2 ECU and non OBD injectors you would need to change the injector clip and remove in the inline resistor box... A P28, P30, or any other OBD1 ECU will not work with a 91 CRX Si distributor... They have a different number of teeth on the spline and fire at a different pulse rate... I just don't get quite what you are tryin to do really only because I do not know the car and motor you are working with... Do you have an EG?? you say "...use my stock VX harness and distributor..." so i assumed an EG but what are you doin with it if i am even correct so far... Hope this helps a little but let us know and we'll probably be able to give you a lot better answer... Latez
Old Jan 6, 2003 | 10:35 PM
GReddy SI's Avatar
Default Re: obd1 harness and distributor ? (Kataku2K3)
well i did some search and i decided to go with obd1
now to get what i need, someone told me to get a
get 97-01gsr or 97-01 typeR harness, and get a p07my stockvx ecu,p30,or p28 chipped
now, having my stock p07 chipped , would it be like a p30 or p28 chipped? what are the advantage and disadvantage of it ?
Old Jan 7, 2003 | 06:20 AM
Kataku2K3's Avatar
You still haven't told us the car or the motor and exactly what you are doing... I really don't have a clue what you are talking about right now... Like I said explain more and we'll probably be able to help... Peace
Old Jan 7, 2003 | 06:36 AM
jmm96gsr's Avatar
why did you even post this topic if your not going to tell anyone what car and what engine you are working with. Its like your just talking to yourself. why even bother posting it??????????
Old Jan 7, 2003 | 10:47 AM
GReddy SI's Avatar
oh sorry
i got a b16a2 from my 2k civic si , and it's going in my 92 hb vx
Old Jan 7, 2003 | 11:05 AM
jmm96gsr's Avatar
just use the stock vx harness and use a p30 or a chipped p28. there are some guys on this board that could hook u up with a program that will work well with your set-up.
Old Jan 7, 2003 | 12:44 PM
Kataku2K3's Avatar
Okay just as jmm96gsr said... use your VX motor loom... You'll just have to add in a wire for the KS... The VX harness has a lot of "garbage" EGR wires which don't do anthing so if you just relocate them you'll be set... I would take the time to modify the harness to fit the B16... You'll either have use the the 2000 Si injectors and modify the injector connector since your VX harness is setup for with the OBD1 clip... I personally like the 96+ connectors just because they look cleaner.. The other option is too just use your VX injectors... A B series and D series injectors are the same at 240cc... I would probably just rewire the connectors and use the B16 injectors since they are newer, but there is not problem going the other way... You'll also have to modify the distirbutor connector.. Just cut your plug off your VX distributor and match all the wires up by color.. The 99-2000 Si has the IAT sensor mounted in the intake tube so you won't have one mounted in the intake manifold runner.... It would be best to get a 99-2000 Si IAT and connector and wire that onto ur VX harness... since the connector is a bit different you cannot just plug the 99-2000 IAT into the VX harnesses connector... The other option is to drill and tap the manifold so that you can use your stock VX IAT sensor.... Another option would just be to use a Del Sol B16 intake manifold with the runner mounted IAT... You'll also have to modify the alternator plug... Hope you can understand this boring **** that i'm trying to explain but it's just the basic **** you need to rewire the motor... If you don't like rewiring then yes you could just get an ITR or GSR engine loom... they are quite spendy (~$500 from Honda/Acura) but everything would plug straight in and the only thing you would have to modify would be adding a wire into the interior wiring harness for the KS it runs out from the shock tower connectors to pin D3.... I find it a lot easier and cheaper just to take your time to modify your stock VX harness.... You can make them just as clean if not cleaner than OE... Good Luck Latez
Old Jan 7, 2003 | 09:56 PM
GReddy SI's Avatar
thanx alot all of this info is very helpful ,
one question , what does a knock sensor?
beacuse i was looking at chipped ecu , and it says
disable knock sensor
and disable speed govern.
what is knock sensor
Old Jan 7, 2003 | 11:52 PM
GReddy SI's Avatar
i wished u lived around here
Old Jan 8, 2003 | 12:29 AM
Kataku2K3's Avatar
haha the KS on a DOHC VTEC motor just detects abnormal vibration, which on a stock motor would be a ping, knock, or detonation... Once you start building a motor you run into problems... Forged pistons are a lot noisier and can cause you ECU to think that the motor is knocking at which time it will pull some timing and dump more fuel to play it safe... A stock KS really doesn't do that much good because it is really only effective on bottom end say ~4500rpm and lower... If you get a chipped P28 or have any other prog that disables the KS then you are set... It's just one less wire to add in... If you want something that will save your motor from detonation etc then look into a J&S Safeguard... It does the same thing as a KS and ECU except if it detects any trace of a knock or anything resembling detoation it will pull timing and change your fuel correction through the entire band... I personally would just get a P28 or get a prog that gets rid of it... Good Luck
7rrivera7
May 14, 2014 03:25 AM
smokeyjpn221
Apr 21, 2010 06:29 PM
bayron
13
Feb 26, 2009 08:04 PM
flatblackhatch
Dec 17, 2005 03:10 PM
IdotheSHOCKER
Jan 9, 2003 07:08 PM
