people that are running no AC no heat.. i need some help
ok well i have all the heater/AC component out of the car except well the heater box that has the hoses going into the engine bay. i was wondering how i should close them off from the motor. can i get a tube and run the hoses from the motor into each other... or should i clamp each one seperate.
i found this from search https://honda-tech.com/zerothread?id=339511 the post mentions "
that means running one hose into the other so the coolant just resurculates (sp).
i just want to double sure of this so i dont blow anything up.
thanx for the help
[Modified by baonest, 10:13 PM 1/14/2003]
i think plugging it would be fine since when you turn your heater control to cold air it stops flow to the hoses...
probably easiest thing would be to loop one hose around.. bypassing the heater core"
thanx for the help
Re: people that are running no AC no heat.. i need some help (baonest)
I will be running mine one hose to the other. I have done this on my mustang wih no problem. You have to think, if the heat is on it will be flowing into the core and back out through the other hose and back into the fluid system.
Re: people that are running no AC no heat.. i need some help (1fasttoy)
Craigc187
08-31-2015 12:18 PM
Aaron Cayabyab
36
06-14-2012 09:20 PM
