for those with ls/vtec (and u built it yourself, or u know of some knowledge or external oil passage
Old 01-09-2003, 02:18 PM
baonest1's Avatar
Default for those with ls/vtec (and u built it yourself, or u know of some knowledge of external oil passage
umm the title has a typo.. oooooops.
i have the earls fittings... now my head is an ITR head and i used a torch to head up the allen bolt thing in the head and i took it out. so now i put in my earls fiting but its not soo easy to thread in.. i figured it wouldnt be very easy. so am i ok, or did i just crossthread the head and should leave the earls fitting in there.
thanx
[Modified by baonest, 6:19 PM 1/9/2003]
Old 01-09-2003, 02:42 PM
tnbigdawg's Avatar
Default Re: for those with ls/vtec (and u built it yourself, or u know of some knowledge of external oil pas
do not cross thread!!! you probably got the wrong fitting.
Old 01-09-2003, 05:36 PM
baonest1's Avatar
hmmmm im pretty sure its the right one.. at first it goes in there good.. then takes some force.. ima take it out gently if posible
Old 01-10-2003, 08:59 AM
Jackson's Avatar
Those fittings are cone shaped so the tighter it gets the better the seal is. Just remember to use hondabond as well.
Old 01-10-2003, 05:16 PM
paulzy's Avatar
NPT and BSPT are different. Either get a converter fitting or just kinda force the NPT fitting in tehre
Old 01-11-2003, 12:49 AM
tinkerbell's Avatar
it is tight it is a BSP thread i think...
make sure you dont over tighten, and use that gas tape or honda bond.
i did not overtightne mine and it diesnt leak...
hth,
t..
Old 01-11-2003, 05:56 AM
baonest1's Avatar
thanx for the info and help guys.
00b18c5
03-13-2009 12:31 PM
a1320honda
04-27-2007 11:13 AM
Del Sol
01-23-2007 02:26 PM
VTC_CiViC
01-30-2006 11:56 AM
baonest
06-26-2002 11:04 AM
Quick Reply: for those with ls/vtec (and u built it yourself, or u know of some knowledge or external oil passage
