which passenger mount to use
which passenger mount should i use , b16a2 in eg
do i use the same mounts that are on the vx motor ,
or do i use my 2k civic si mounts?
haha, I thought we didn't have a chasis choice here....
IF you're putting a B16A2 into a EH hatchback, you can use Del Sol VTEC or 2000Si VTEC mounts. I believe you only need the rear mount, anyone?
By passenger mount are you referring to the tranny mount? If so, you can use the one from your stock motor. The 00 Si mount is different and can only be used in the 96-00 Civic's.
yes i am referring to the tranny mount , ok
i can use both from my stock vx motor then right ,
if i take off that metal backet from the tranny ,and put the vx one on
that way i can use the tranny mount correct?
Well the top tranny mount can be the stock VX one but the front tranny bracket must be a integra or del sol vtec bracket. The SOHC one won't work there.
OK cool because i was wondering if i needed a g3 teg one ,
but i have the stock b16a2 on the motor still
so i can use that one ,
97civicdx
Feb 9, 2005 12:32 PM
jameskersten1
Aug 27, 2003 12:02 PM
