My Intermediate shaft support keeps comming off! HELP!!!!
Old 01-10-2003, 03:06 PM
MeanGreenEG9's Avatar
Default My Intermediate shaft support keeps comming off! HELP!!!!
I noticed a few weeks ago that the metal support peice from the half shaft that bolts onto the block came loose so bascially that piece was just swinging back and forth while i drove the car. I placed three bolts in the holes and bolted it up but I noticed for some reason I could not get the bolts to fit snugly in place so I tightend it as much as I could. After a week of driving i noticed two of the bolts had come undone and today the last bolt came off!!
How can i get the bolts to go back in? obviously the threads are stripped or something otherwise it wouldn't be so easy for the bolts to come out. Any suggestions?
Old 01-10-2003, 03:31 PM
Kataku2K3's Avatar
Default Re: My Intermediate shaft support keeps comming off! HELP!!!! (SlowAssB16a)
Go up to next available size bolt or you could helicoil it back to stock... All a helicoil is, is a thin steel insert... It is actually stronger than the stock aluminum block... That's what i would do in your case... You'll either have to pull the axle/intermediate shaft or flip the mounting bracket down so that you can retap and either go with a new oversized bolt or a helicoil insert.. I just found this link to show you what a helicoil is incase you didn't know... hehe http://www.hillcliff-tools.com/helicoil.html Good Luck
Old 01-10-2003, 04:38 PM
Default Re: My Intermediate shaft support keeps comming off! HELP!!!! (Kataku2K3)
Thanks for the help dude.. I'll try that helicoil thing but wouldnt it work if i just use a larger bolt? maybe not.. i dunno.. i'm startin to hate my car
Old 01-10-2003, 04:54 PM
VTECVillain's Avatar
Sounds like the threads are stripped from cross threading the bolts or something. You might be able to rethread the holes or use the helicoil inserts if not.
Old 01-10-2003, 05:22 PM
Default Re: My Intermediate shaft support keeps comming off! HELP!!!! (VTECVillain)
I'm pretty positive that I stripped the threads.. is that helicoil supposed to work definitely?? what are my other options?
Old 01-11-2003, 04:48 AM
1fastVX's Avatar
Use the Helicoil.....when I got my swap one of those exact bolts was stripped...so I headed over to NAPA auto parts and picked up the Helicoli kit...worked great!!...just be patient and vaery careful when u are installing it...good luck
Old 01-11-2003, 08:20 AM
Nameless RB26's Avatar
Default Re: My Intermediate shaft support keeps comming off! HELP!!!! (1fastVX)
Either a helicoil or just rethreading it a bigger size will both be fine. If you rethread it a bigger size, you should drill it out smooth first, and cut brand new threads. Be carefull
Old 01-13-2003, 08:17 AM
TORQUE MONSTER's Avatar
man I just did a search of all ur post.. YOU have some ******* problems with ur car.. sigh!
JJGL-EF90
10-08-2010 01:27 PM
tempsohc
05-14-2009 01:08 AM
StreetRacinThug
03-27-2006 09:29 AM
MeanGreenEG9
01-10-2003 07:15 PM
tyler
12-20-2002 10:59 PM
Quick Reply: My Intermediate shaft support keeps comming off! HELP!!!!
