CTR pistons in B18a with B16 head and big cams????
Old 01-11-2003, 01:10 PM
JDMCRX's Avatar
Default CTR pistons in B18a with B16 head and big cams????
Im just wonderin besides the compression being high im wonderin if we are goin to have Valve to piston problems?? with the stock head gasket???
Old 01-11-2003, 02:38 PM
HT's Biggest Loser
SIXTYdashONE's Avatar
Default Re: CTR pistons in B18a with B16 head and big cams???? (JDMCRX)
Big Cams? do they have a brand name or did you widdle them from a peice of wood, what kind are they, and depending on how "big" they are, they might be.. use clay bar
Old 01-11-2003, 02:54 PM
JDMCRX's Avatar
Default Re: CTR pistons in B18a with B16 head and big cams???? (SIXTYdashONE)
There CAT CAMS there made Beljum
Old 01-11-2003, 03:20 PM
743power's Avatar
Compare their specs to toda spec c's. If they're close or higher, than they won't work.
Old 01-11-2003, 03:59 PM
JDMCRX's Avatar
Default Re: CTR pistons in B18a with B16 head and big cams???? (743)
Im pretty sure there smaller then the TODA C's
Old 01-11-2003, 06:20 PM
RenoRacing's Avatar
depending on how big. anywhere from 10.2(w/ ITR pistons) to about 11.9(some really high compression pistons.
here's a bad *** site.
http://www.c-speedracing.com/howto/c...c/compcalc.php
Old 01-11-2003, 07:37 PM
function83's Avatar
Default Re: CTR pistons in B18a with B16 head and big cams???? (HavokRacing)
*belgium
just clay your motor.
HydroBudz
10-26-2005 05:11 AM
b18c5 EG
22
06-19-2005 09:41 AM
tinkerbell
07-22-2004 10:09 AM
Chris
08-22-2002 09:56 AM
Quick Reply: CTR pistons in B18a with B16 head and big cams????
