The very far vacum line on the Skunk2 manifold????
I just seen a post on this but i cant seem to get back to it. What is that vacum line go to ?? the one right by the fuel psi regulator, far right if the manifold if its on the engine(GSR). Its throwing a code but it runs fine, the idle surges a bit but then levels out. Thanks,
Re: The very far vacum line on the Skunk2 manifold???? (B16poweredEF)
one goes to PCV, the one next to it goes to the fuel regulator, the one behind it goes to your charcoal canister evap.
Re: The very far vacum line on the Skunk2 manifold???? (Nameless)
Oh ok its the one in the picture that is connecting to the fuel psi regulator. At least in your picture it does. Thanks guys.
Ok, that still leaves 2 vacum lines without a place to go. The one i had going to the FPR was coming out of the black vacum canister under the manifold. B16poweredEF is my bro and he posted that for me the problem is in my hatch. Its a GSR motor one of the lines went to a IAB diaphragm that controls the secondary butterflys(i think), the second one has no were to go. Anybody know what i'm talking about?
[Modified by leadfoot78, 9:56 AM 1/9/2003]
Re: The very far vacum line on the Skunk2 manifold???? (leadfoot78)
did you accidently switch the purge evap sensor with the IACV? This might be your problem with the CEL and the surging IDLE.
Re: The very far vacum line on the Skunk2 manifold???? (Cnote)
I don't think so i labeled them, my problem is two vacum hoses with no place to go. Both of them come out the black vacum tank under the manifold.
Just get a vacuume T and connect the nipple that the guy above is pointing to to the line the FPR is connected to.
That's what I did.
That's what I did.
Re: The very far vacum line on the Skunk2 manifold???? (Trey)
Ok, get a vac line running directly from the FPR to the top right nipple on the manifold. Then, take the evap purge solenoid and run a vac line to the bottom right to it. The surging idle can defintly be from confusing the eletrical connectors for the evap and the IAC sensor.
That's what I did.
That's what I did.
The one I'm pointing to has something to do with the cruise controll - I just put a cap on it. If you take the cap off though, prepare for major surging.
Really? What does that do? I'm intersted if there's something I should be doing..
I left the last line that goes to the diaphram(secondary butterflys) just hanging and i'm not getting any codes or surging idles, i have not reved it past 3k though.
33
06-12-2009 03:58 PM
