H22a swap in 94 accord (P/S hose question)
I'm doing a swap for a friend and I think I have everything but since this is my first H22 swap I am not familiar with it. I was reading somewhere that the accord power steering hoses will not work with the H22 power steering pump. can I use the accord power steerig pump on the H22? does HASport make a hose for this application, or do I have to combine both hoses.
Re: H22a swap in 94 accord (92JDMSiR)
you can use the accord's P/S pump...i dont know why but some people doing the swap they have to use the H22a pump for...cuz they have to custom make a line that fit the h22a pump...when you put the p/s line on the pump you'll notice it's a lil tight...just pull on it like it should fix fine....and the brackets...play around with it...use combination of the F and the H serie...either way you got both of them there....
