will 99-2000 JDM ecu's fit 96-98 obd2 wiring harness?
I know the usdm 99-00 harneses have different sized plugs but wasn't sure about jdm ones.. thanks in advance
Re: will 99-2000 JDM ecu's fit 96-98 obd2 wiring harness? (SlowAssB16a)
96-98 Civic = OBD2a using plugs A,B,D
96-99 Teg = OBD2a using plugs A,B,D
99-00 Civic = OBD2b using plugs A,B,C
00-01 Teg = OBD2b using plugs A,B,C
They are the same whether they are USDM of JDM but you'll just have to make sure that you aren't trying to plug an OBD2a harness into an OBD2b harness or vise versa... Hope this helps.. Peace
Re: will 99-2000 JDM ecu's fit 96-98 obd2 wiring harness? (Jackson)
The 96-01 jdm itr ecu plugs are the same as the usdm 96-98...HTH
Re: will 99-2000 JDM ecu's fit 96-98 obd2 wiring harness? (poison)
The 96-01 jdm itr ecu plugs are the same as the usdm 96-98...HTHYes, this is correct.
Well I guess it should fit if for some reason they don't have OBD2b over in Japan... What plugs does the ECU use?? A,B,D??
[QUOTE]The 96-01 jdm itr ecu plugs are the same as the usdm 96-98...HTHYes, this is correct.
Actually I'm looking to use a 2000 JDM CTR ecu in my 96 ex wiring harness.. this should fit? I know i've asked but I want to make it clear that its ctr ecu NOT itr ecu.. thanks[/QUOute]
The ctr ecu will plug into 99-00 ecu plugs. Honda is weird like that. I don't get it.
98civicEX
02-14-2003 06:22 PM
