which ecu???
Old Jan 8, 2003 | 08:10 PM
h22dx's Avatar
Default which ecu???
im gonna do the h22 swap into my ek hatch. should i go with the gsr ecu or the chipped stock????
Old Jan 8, 2003 | 08:12 PM
EK MONEY's Avatar
Default Re: which ecu??? (h22dx)
chipped P28.
Old Jan 8, 2003 | 08:34 PM
h22dx's Avatar
Default Re: which ecu??? (Peagreenhatch)
the mugen chip i can redline at 9200!! will i need to upgrade anything else for this?? like fuel injectorsor anything? that would big big *** power!!
Old Jan 8, 2003 | 09:04 PM
Kamin's Avatar
no, not a mugen program.
get the STOCK h22 program
or get an OBD2/1 (if you are converting) h22 prelude ecu.
you have no need for a mugen program.
and just because you could rev that high dosent mean you will make power.
you would need cams, valves, valve springs, retainers and some tuning for 9200rpms.
just get the stock ecu/program for the h22.
[Modified by Kamin, 1:24 AM 1/9/2003]
Old Jan 9, 2003 | 06:44 AM
eg6ajk's Avatar
OBDI P13 with a Spoon or stock program best there is. second best is a GSR ECU + VAFC, then chipped P28.
Old Jan 9, 2003 | 12:08 PM
h22dx's Avatar
Default Re: which ecu??? (eg6ajk)
so get a spoon chip for the stock obd 1? can i put that in myself? what will the chip do?
Old Jan 9, 2003 | 12:41 PM
Kamin's Avatar
no
not a spoon chip
let me explain somthing, those chips are for modified cars, higher revlimit, diffrent vtec crossover, etc
you have a BONE STOCK motor.
you need the BONE STOCK ecu.
get the prelude ecu.
and chipping an ecu cant be done by yourself unless you have a rom writer and the entire program.
Old Jan 9, 2003 | 04:02 PM
eg6ajk's Avatar
Default Re: which ecu??? (Kamin)
no
not a spoon chip
spoon programs are very streetable programs. they are designed to be used for amateur racing. all have more aggressive maps then stock, no speedlimiter and fix few dead spots found on some motors. fuel economy doesn't suffer nor does engine damage occur if the ecu is used in proper manner.
I offer DIY kits for $39 shipped which require you to solder in new parts. thats all.
hopelesspsyko
May 24, 2009 11:44 AM
HoNdAmAn29
Feb 25, 2004 01:08 PM
chaudanova
Jan 13, 2003 10:25 AM
prjctCIVIC
Dec 20, 2002 12:13 AM
