97 D16Y8 into 90 DX hatch - What's needed for complete swap?
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Okay, my buddy's got a 97 D16Y8 complete swap (except for axles) that he's selling to my other friend for his 90 civic dx hatchback. I need a COMPLETE list of everything that is needed to complete the swap. He said the motor came with the tranny and ECU, but didn't say what else it came with. What else is needed for the VTEC conversion into a non-VTEC car? I know nothing about hybrids, I'm going the turbo SOHC route myself
Thanks in advance for the help
Re: 97 D16Y8 into 90 DX hatch - What's needed for complete swap?
http://www.boomslang.us/obd0to1.htm
cheapest harness you can get read the instructions its easy and you need one for dpfi
p28 ecu
cable trans
ask me if you need anything else
p28 ecu
cable trans
Technical Hero
-Convert from DPFI to MPFI using your engines wiring harness
-OBD0-OBD1 ECU harness with P28 ECU with Y8 basemap
-OBD0-OBD2 Distributor Adapter
-Solder on OBD2 injector plugs
-Reuse OBD0 alternator
-Wire up VTEC solenoid, VTEC pressure switch, and 4 wire O2
-Wire fan switch from the back of the block to the thermostat housing
-Insert intake air temp sensor into your intake arm from the B2
-Reuse drivers side engine mount (mount attached to the block from the B2 engine)
-You can use the transmission but you'll need a cable to hydro kit
-Ignore knock sensor on back of block, CKF sensor on crank, EVAP purge on fuel rail
-Either use the MAP sensor on the firewall or the throttle body mounted one
-Reuse cv axles from either motor
-Sell for profit P2P ECU, knock sensor, and OBD2 alternator
hey hondapartshero...i put a y8 into a 95 hatch which harness do i need mine are all broken off and used up? im guessing obd1 to obd2 adapter and with vtec solenoid n pressure switch...also got ne thing for the thermostat my wires are broke at connector..
Beto1995
12
06-30-2013 03:33 PM
rhdekhatchie
11-10-2007 07:59 AM
