quick mount and hose question
Old Jan 8, 2003 | 03:21 PM
thehatchninja's Avatar
Default quick mount and hose question
Which mounts and hoses do i need for my B18C to go into my CX? thank
Old Jan 8, 2003 | 05:31 PM
Default Re: quick mount and hose question (thehatchninja)
c'mon i know someone knows this off hand
Old Jan 8, 2003 | 06:00 PM
Soled Out's Avatar
http://www.hasport.com/Tech/Installs...%20bseries.htm
That link has exactly what your looking for
Old Jan 8, 2003 | 06:34 PM
Default Re: quick mount and hose question (Gray EG)
all it says about mounts is that a combination of stock integra and civic mounts can be used
Old Jan 8, 2003 | 06:39 PM
Soled Out's Avatar
Use the integra timing belt side mount, AC bracket ( use the rubber from the civic)
passenger side front tranny mount from an integra (use the rubber mount off the civic) rear tranny bracket from integra
Old Jan 16, 2003 | 12:19 PM
Default Re: quick mount and hose question (Gray EG on Jack Stands)
thanks
Old Jan 16, 2003 | 01:39 PM
jmm96gsr's Avatar
also use your stock civic top tranny mount. Just thought i would add that.
Old Jan 16, 2003 | 04:53 PM
Default Re: quick mount and hose question (jmm96gsr)
son of a m@#%$^F@#$#&................i didn't get a driver side upper mount with my swap.......well i'm going to the junk yard tomorrow to get my shift linkage anyways....guess i'll pick one up there.............also i'm missing the top bolt in the rear mount, and none of the bolts from my D16 mounts fit it......that will be a p.i.t.a. to get off of a doner (sp?) car..
turboxsi
Feb 16, 2005 05:41 PM
97civicdx
Feb 9, 2005 12:32 PM
TYPE_EG6
Jan 2, 2005 04:41 AM
blueintegra90
Jun 11, 2004 04:03 PM
crx8psi
Jan 19, 2004 08:29 PM
