B18c into an "EG"
B18c into an "EG"
B18C swap into a 92 VX hatch........
any different mounts?
wire up pretty much straight forward?
did a search, and didn;t find the info i was looking for, so a past topic, or some answers would be great!
THANKS!
MIKE
THANKS!
MIKE
Re: B18c into an "EG" (neonxrt)
use stock mounts, and u will have to switch two wires for the IAB. also add a knock sensor.
please search for the wiring, cause i dont' remember it.
92 civics are already wired for vtec. so 3rd gear powaa to yaaa
you need to add some wires between the ecu and the motor. You need to run one wire for the secondary butterflies (IAB), and add a knock sensor wire. Just cut and run a wire from the corresounding locations (IAB + KS) tp the ecu . Find out exactly which locations to run your wires to on the ecu...
Re: B18c into an "EG" (bigblockEG)
ok, good. it sounded like i had to get a bung welded in, and add a whole sensor. adding a wire is a piece of cake. and as i said before.......OBD1
MIKE
MIKE
drpepper
09-07-2005 01:53 PM
