Question about ls/vtec & CR-Vtec timing belt/water pump
Will an LS timing belt work for either frankestien if used with LS/B20b water pump?
Or you do have to use the Vtec Timing belt and a Vtec water pump?
This is for a b20b with b16a head.
[Modified by TDCPerformance, 6:04 PM 1/4/2003]
Re: Question about ls/vtec & CR-Vtec timing belt/water pump (TDCPerformance)
i think you can use the LS timing belt as long as its the LS water pump.. but if you use the VTEC water pump.. you need to use a GS-r or ITR timing belt since there are more teeth on the water pump pulley.
thirsk66
10
05-22-2013 02:26 PM
