B16A first gen install
Old Jan 9, 2003 | 11:22 AM
ITR632's Avatar
Default B16A first gen install
Installing a B16A first gen into a 98 civic DX what all do I need, or the web site that give all the info.
Thank you
Old Jan 9, 2003 | 12:33 PM
Kamin's Avatar
Default Re: B16A first gen install (ITR632)
you need to buy the correct motor for your car
you will spend just as much getting the first gen motor to work in your car.
the 650+ alone for the cable to hydro conversion makes up the diffrence for a second gen.
Old Jan 9, 2003 | 12:43 PM
ITR632's Avatar
Default Re: B16A first gen install (Kamin)
Thanks for the input ***, it is not my engine or my car I was trying to help someone that has the engine with some info on what he need.
Old Jan 9, 2003 | 02:02 PM
NiMhist's Avatar
He is right though, tell your friend to sell the 1st gen and put the money towards an A2. It will be A LOT less hassle.
This is my opinion so please don't call me an *** too, it lowers my self image.
Old Jan 9, 2003 | 02:16 PM
Kamin's Avatar
excuse me?
**** YOU
never once did i disrespect you, I didnt scream, call you a moron, cuss at you, etc
i just said it would be EASIER if a second gen motor was used.
now you can ******* fend for yourself because im not helping you.
*******, you need to learn how to respect people.
Old Jan 9, 2003 | 02:22 PM
Pat McGroin's Avatar
excuse me?
**** YOU
Good move man, I was about to type in that no one should help him.
Old Jan 9, 2003 | 03:19 PM
lazy bum shaughn's Avatar
excuse me?
**** YOU
EXACTLY why he has 99%.
Old Jan 9, 2003 | 10:10 PM
ITR632's Avatar
Default Re: B16A first gen install (lazy bum shaughn)
lol kids . U never helped in the first place. Just told me what I already know. But thank you soooo much for the great input it is very much appreciated. Is that better?
Old Jan 9, 2003 | 11:12 PM
b20em1's Avatar
not sure if this would work for a 98, but here goes.
step #1: sell cable tranny
step #2: buy b-series hydro tranny
step #3: buy chipped ecu
step #4: buy obd2 distributor
step #5: by 99-00 si shift linkage
step #6: install
btw, i just got this from searching, but i woundnt put an older engine in the car.
[Modified by natural, 8:25 AM 1/12/2003]
Old Jan 10, 2003 | 08:03 AM
ITR632's Avatar
Default Re: B16A first gen install (natural)
Yea I agree but it is not for me, I tried to tell the person thats buying this that it would be easier to go with an a2, but you know how people are when they have their mind set on something....
Old Jan 10, 2003 | 11:11 AM
vivid02's Avatar
Does he have the first gen motor and tranny? Did it come out from an integra XSI? This is what you should do if the answers are yes.
GET.
99-00 Si dist.
99-00 Si shift linkage
99-00 Si rear mount bracket
99-00 Si engine mount bracket...bolts on the the block under the timing belt.
Cable to Hydro tranny conver. mount from place racing, hasport, HCP.
OBD2 to OBD1 ecu jumper harness with chipped P28 ecu. Since you wont have all of the obd 2 sensors on the 1st gen motor.
Old Jan 10, 2003 | 11:12 PM
jumpmann23's Avatar
From: Your really lame if you dock my points, WA, 98033
sell cable tranny for hydor b series tranny
get obd1/obd2 injectors depends on which you want to go
get obd1/obd2 distributors
(only if you want to go obd2) obd2 gsr or b16 oil pump crank angle sensor
Ek b series mounts
99-00 shiftlinkage
95+ hydro b series axles and midshaft
hydro B series clutch
obd1/obd2 ecu
id also get rid of that b16a1 Intake manifold and throttle body.
i figure you can sell/trade some of the stuff you need. i know Cable B16a trannys are in demand. and they sell for as much if not more than hydro b series trannys.
good luck on your swap
siopau
May 13, 2011 08:21 PM
turbocvcsi
Sep 26, 2006 07:02 AM
7thGear
Jul 11, 2003 08:52 AM
juicy.koreans.suck
Jan 27, 2002 05:20 PM
