ITR swap into 94 Del Slo SOHC VTEC,, wiring questions!!
im doing an ITR swap into my buddies 94 del SLO si SOHC VTEC. i have everything covered, just except for the wiring. as in,, what else is needed to be wired up? what harness to use? what ECU?
he has 97 USDM ITR wiring harness, i was told this will plug into the DEL slo's wiring harness at the firewall?? he will be running a rechipped p28 ECU (OBDI) is any additional wiring needed??? will that harness work for me? or use the stock del SLO's? thanks to anyone that help me out on this subject.
Re: ITR swap into 94 Del Slo SOHC VTEC,, wiring questions!! (JDM CRX)
you should be able to reuse the Del Sol harness.. since it is already wired for VTEC.. only problem i see now is finding an OBD1 distributor and fuel injectors.. other than that, everything else is plug and play. good luck.
digital sol
06-29-2006 12:32 PM
JDM CRX
01-14-2003 04:38 AM
