What compression do yuo think I'm @????
I have a 94 gs-r motor all stock except ctr pistons in my car. What compressin do you think this is @??? Does anyone know how much I can spray on this setup and be safe??
HT's Biggest Loser
Re: What compression do yuo think I'm @???? (95c1v1cs1)
umm, if im not correct, i think standard bore CTR pistons in a gsr motor were 12.3:1 compression....and if i was u, i wouldnt suggest spraying on them..if im wrong, soemone please correct me. thanks, good luck..RON
Re: What compression do yuo think I'm @???? (SIXTYdashONE)
I get 12.04:1 from here:
http://www.c-speedracing.com/howto/c...c/compcalc.php
and 12.32:1 from here:
http://www.bojangs.com/calculator/
Why not spray on them? Not even a 50 shot? I want to be able to do 12's one I'm done and I don't thin it will do it all motor.
HT's Biggest Loser
Re: What compression do yuo think I'm @???? (TurboB16Coupe)
12.3:1 is alot of compression and heat on non-forged pistons. Remember, your pistons may be CTR, but they are just stock honda pistons, only with alot higher risk of blowing up. adding nitrous to this mixture could be disastrous..is the number 12 really as important as blowing your motor?
WhoDoYouThink
10-04-2005 01:02 AM
