Can i install a b16a1 from a 91 model into a b16a2 94 motor?
hey... my b16a2 engine has signs of blowby, i'm gonna rip the complete block wiv head and change it with the b16a1 engine, is this possible? i will use all the existing manifolds and sensors with the b16a2 block and just drop the older engine for a little while... will it be okay or will i come across sum probs?? the dizzy and mounts will be used from the b16a2 motor... also its got the drag gen 3 kit installed too....
HT's Biggest Loser
Re: Can i install a b16a1 from a 91 model into a b16a2 94 motor? (sunny79)
Your post title asks if you can install a motor into a motor...and to answer your question, there will be no problems just swapping blocks, just make sure you use the correct harness from your A2.
actual block/head is identical, just swap over your mounts, intake, exhaust manifold, with all the elcectronics. don't forget the thermostat housing with the newer type and location of the coolant sensor. other then that its all okay
ludesleep
04-08-2003 05:27 PM
