LS cat vs GSR cat in Swapped EG
I currently am running a eg with a gsr swap, for the exhaust setup i am running a stock header to a ls cat and onto a apexi n1 catback, the exhaust fits kinda of shitty like the ls cat is to long? Is there a difference in length between the gsr and ls catalitic converters?
Re: LS cat vs GSR cat in Swapped EG (95c1v1cs1)
GSRs have O2 sensors on the cat.
Not sure if LS has them.
GSR cats are 17 inches long i am pretty sure.
Re: LS cat vs GSR cat in Swapped EG (HybridHatchC1)
its 16.5 inchs i think, and if you run an LS/b16 header to that cat, it shoudl line up, GSR headers are about 4 inchs longer then the ls/b16.
LOVEthatDC2
05-30-2009 10:10 PM
