91 integra with 97 jdm b18c vtec. wont idle or run good.
my 91 acura integra has a fresh 97 jdm b18c type r vtec with a jg elderbroke intake. i had it running last saturday. the engine ran awesome then after 77miles it went into limp mode? so i changed the tps and map sensor. now its wont idle or run unless i keep on constantly keep on pumping the throttle a little bit at a time. and if i pin the throttle the engine will just die. i check the timing and changed the fuel filter the pressure stays around 50 psi. it has a adjustable fuel pressure regulator. help please
Re: 91 integra with 97 jdm b18c vtec. wont idle or run good.
i believe we're having the same issue...so i'm interested in the answer as well...
spec:
chassis: 1996 Civic CX OBD2A
engine: JDM 1998 B18C Type R OBD2A
ECU: JDM p73 (which is why i am on honda-tech instead of staring at a obd-scanner)
wire harness (if it matters): 1998 civic SOHC vtec
I don't think a test-pipe and a shortram will contribute to the problem, but i am rocking those two mods right now.
problem: my car is in limp mode...it will not go over 6600 rpm, vtec does not engage, and I have trouble starting the car when cold. It idles at like 100 rpm and as soon as I step on the gas it dies out. I have to let the motor run for a bit before I can drive it.
I've looked on google searched on H-T all with similar problems with solutions, yet the solutions don't solve my problem. :\
It would be great if i can get some help here as well too :D
spec:
RGuo921
08-06-2010 11:24 PM
91integi
07-20-2010 09:12 AM
sleepyEK
09-06-2005 01:14 PM
