clockwise b-series
Old Oct 24, 2010 | 07:46 AM
integraturbo96's Avatar
Default clockwise b-series
I do some search on google but I can't find some concrete information about this.
I have a little project in my head but I need some info to run a b18 clockwise.
So the point that I have to look
Lubrification, external oil pump or its possible to make the oem work
Cooling, electric water pump?
Cam shaft, need a regrind or its possible the run clockwise
Firing, can a use a stock dizzy and move wire location to have the good cylinder firing timing
Thank in advance
Old Oct 30, 2010 | 04:08 AM
purplecivicturbo's Avatar
Default Re: clockwise b-series
Thank in advance
I toyed with this a while back, to try and use a proper 4wd tranny.. Unfortunately there are a few problems, as you say;
1- the cam lobes need to be symetrical, and the dizzy is offset on the cam- so you would need some form of an adapter i would think.
2- cam belt tensioner is on the wrong side of the belt
3- electric water pump
4- dry sump or external oil pump
*getting expensive now
5- the pin though the piston is off centre, to aid crossing tdc. to fix this you can rotate the piston 180deg, but the valve reliefs would then need work
6- also, the oiling of the crank is done bearing in mind that the force of combustion is occuring in a specific area, by reversing the engine, this area is moved- you wont be getting the designed amount of lubrication
hopefully this helped...
Old Oct 31, 2010 | 03:28 PM
Thx, I forget the crank lube issues. Seem a big problem to make it work
Old Nov 1, 2010 | 05:36 PM
canadaek's Avatar
buy a k series .
VTEC+Mini
Jun 16, 2012 08:34 PM
squareback
Jan 9, 2012 02:22 AM
xkwzt21
May 14, 2008 05:31 PM
SiYouLater
Jun 3, 2007 08:37 PM
macmanboomer
Jan 12, 2007 08:18 PM
