pure odb1 crx!
pure odb1 crx!
i have a crx shell with no engine harness or what so ever, and i have a b18b motor on my ef hatch and was converted to pure obd2..my plan is to use the b18b and transplant that in my crx and use a pure obd1 engine and dash harness from an integra...will this work? can i use the whole harness without modification? pls help me, i'm really stressing right now..
Re: pure odb1 crx!
if you have... "...no harness what so ever..." get a harness from a donor car (junk yard, craigslist, whatever can guarantee a good harness.) Original shell wiring would be a route. and then a harness from your motor to that might even involve and obd conversion so consider that as well. get all the free pdf files online of the tech manuals with wiring schematics. READ...FOLLOW...moreREADFOLLOW....
....google and ht search is your friend.
-also check dizzy wiring and ecu compatability
Last edited by defnu; 10-16-2010 at 10:37 AM. Reason: -also check dizzy wiring and ecu compatability
Re: pure odb1 crx!
1.yes and no
2.yes and no
but do not be intimidated...little mods are needed to what you have if you're down to read and label some wires and taking time to secure each connection wether it be by crimpers or solder.
brandonEM1
Engine Management and Tuning
11-24-2013 04:21 PM
