issues with d16 will b16a2 swap solve them?
Re: issues with d16 will b16a2 swap solve them?
It depends on the model year. It also depends if parts of the engine harness or dash harness were hacked up for a V-AFC or an alarm. Corner lights are sometimes just bad flasher relays or corroded connectors in the light housings. Sometimes it's wires that have been rubbed through and are grounding out on the frame.
Post up what motor block the car has, what year and trim level it is (example 95 Civic EX), and what appears to have been changed recently. Different years & trim levels require different things. Help us help you...
popv1995
08-21-2015 09:04 PM
