h22a4 eg swap questions
So I just completed my first Honda engine swap by myself. I swapped a 97 h22a4 non SH into my 93 ex coupe. the car runs. fired right up.
Im running an f22 transmission 5 spd. what intermediate shaft do i run ?
I have the intermediate shaft from the h22a4 automatic.
also what radiator hoses do i run? I have all the coolant hoses ran but my radiator hoses. i can not seem to find hoses that fit the small diameter radiator inlet and outlet and the larger diameter h22a4 water necks.
ive asked questions on other honda forums (hondaswap.com) but no one would ever answer.
I have been researching this for hours but can not seem to find the information I need.
Re: h22a4 eg swap questions
Your radiator is going to be small for that motor, I suggest at least upgrading to a dual core del sol radiator, it also has larger hose inlets on it so that gets rid of one issue.
For hoses, I would buy a set for a 94+ integra LS. The bottom will fit fine, just cut to fit for the upper hose...
the hose choice sounds good, but i would not about the radiator, i am running a 97 h22a4 in my 93 eg withtthe stock radiator and just water. runs fine in 95 degree days.dont spend money you don't need to
chb93
04-28-2010 12:47 PM
DIRTYsouthBB6
11-17-2005 08:51 PM
handa
06-19-2004 12:51 PM
