Auto to Manual LSVTEC Problem!!!
Old Jul 21, 2010 | 07:03 PM
beamer's Avatar
Default Auto to Manual LSVTEC Problem!!!
Alright well i just finished up my auto to manual lsvtec setup and i came to find that i have no spark or fuel! What could it be!!!
Main Relay is new
Distributor is new obd2a
Spark Plug wires are new
Spark Plugs are new
Running obd1 p72 on s200
Ive heard that the knock sensor has something to do with the spark but since the block doesnt have a knock sensor i cant do anything about it but the distributor is obd2a.
What else can i do!!! I need help asap! 9562362077... call would be better but anything helps!
Old Jul 22, 2010 | 09:21 PM
accord3955's Avatar
Default Re: Auto to Manual LSVTEC Problem!!!
have you done any pin out? and we need more info.....what's the shell and what years of wiring do you have
Old Jul 23, 2010 | 06:42 AM
RenownPer4mance's Avatar
Main Relay is new
Spark Plugs are new
Check the pgm fi/ecu fuse/s
Old Jul 23, 2010 | 03:34 PM
Gsung's Avatar
have you bridged the plug that goes to the auto shifter .
Old Jul 24, 2010 | 03:56 PM
beamer's Avatar
obd2 ls harness (wire vtec with the sub harness) since its lsvtec
the only pin outs ive done are to wire vtec....
all the fuses are fine and the main relay is brand new and still not getting any spark and fuel.
i cant seem to find the problem!
Old Jul 27, 2010 | 04:48 PM
beamer's Avatar
Anybody?
Old Jul 29, 2010 | 07:43 AM
HAMOTORSPORTS's Avatar
Main Relay is new
Spark Plugs are new
The knock sensor will not affect the car being able to start.
Old Jul 29, 2010 | 06:38 PM
beamer's Avatar
Does anybody think I have a short somewhere? All my fuses work fine! And main relay is new!
Old Jul 29, 2010 | 06:39 PM
beamer's Avatar
Crank sensor!!!!! How about that?
I'm running obd1 block obd2 distributor and obd1 ecu.
Old Aug 3, 2010 | 05:13 PM
beamer's Avatar
bump
JDM-sol 89
Feb 10, 2019 09:00 AM
GotaMin
Aug 13, 2008 08:03 PM
itrintegra
Oct 3, 2007 02:34 AM
dogbiscuit
25
Nov 2, 2005 11:47 AM
dr_latino999
14
Aug 11, 2005 01:18 PM
