AUSTRALIA 88 EF B18C swap wiring problems help please!!
Hi, im from Australia and am swapping a b18c into a 88 ef.
Problem is that the Australian delivered d15b4 engines in our EF and even early EG models have dual carburettor fuel systems, so it is at this point I am stuck with what wiring harness to use.... I have a DC2 donor car so all wiring from that car is right here. But I have read in places that it is best to keep the existing harness. So if anyone could help me that would be great. Please dont just say search because I have and I cant find anything about changing from a d series carbed engine to a B series OBD2a engine.
Also if I do swap the wiring harness for the one from the dc2 then will the speedo cluster and all still work?
I have also posted this in the EF CRX forum.
Thanks in advance.
Thanks in advance.
Re: AUSTRALIA 88 EF B18C swap wiring problems help please!!
thanks for the reply, yeah im sure the cluster will need to be changed over and the fuel pump but why the tank?? am i missing something? Thanks
u have an electric fuel pump in the fuel tank thats why u need to change it carby model eds run them off the camshaft. some cars with electric fuel pumps in the tank r only low pressure ie. 6-10psi efi fuel pumps can goto 100psi but u only run them at about 50ish
thats why u change it
sepetinswenze
11-25-2010 05:25 AM
