ignition problem
Old Nov 13, 2010 | 04:28 PM
accord2civic2prelude's Avatar
Default ignition problem
when i connect the negative battery terminal, the fuel pump primes and the gauge cluster comes on as if the key was in.
i check all fuses, unplugged the ignition switch harness(both) from under steering column. i unplugged all 3 shock tower plugs. funny thing is, when all 3 are unplugged, the gauge cluster(brake and check engine) lights are still on. when i plug in the 2nd largest, the fuel pump primes. what else should i check?
radicaled434
10
Apr 27, 2012 04:10 PM
Nov 15, 2010 11:09 AM
Nov 14, 2010 01:46 PM
beana
May 26, 2009 07:26 PM
b18-c-rx
10
Jul 17, 2005 02:10 PM
