h22 shifter box question here....
Re: h22 shifter box question here....
You will probly need the cables for that specific box. I had an odd ball shifter box come with my swap, i ended up getting 92-96 prelude box amd cable setup. A late model plastic box could work to but i still think the cables will need to match the box.
what shifter box do i exactly have with the "reservoir" section that hangs down? i am assuming a gen4 prelude box.
I think your raised shift box might work ( obviously you are going to have an ugly interior ) You know, like some thick washers or something would work.
I dont have pictures of it assembled fully. Since then it has been painted flat black. sorry for un-quality like pictures.
Nice l00d shifterknob
actually here is the shifter box i have... after doing some research... seems to be a accord shifter box... idk what year... but it has the sealed resevior for grease i am thinking, and instead of the cable attached in front of the shifter level, its like branched off and pushed to the right. and the other cable is in a different spot too...
EDIT: Another picture of my type of shifter...
i think it would be a super nice setup if you could adapt the hyrbid racing shifter to some h cables. then no cutting of the floor.
http://www.hybrid-racing.com/store/d...t-shifter.html
Thats the shifter box i had with my swap. i tried both accord and prelude cables from the junkyard and neither fit. But the cables could have been labeled wrong also.
