P28 or P72
Old Oct 26, 2010 | 10:13 AM
deauboy's Avatar
Default P28 or P72
I'm am extremely ignorant when it comes to ECU's and from what I have found searching for this answer nobody actually answers it.
I am going to be tuning my 97 JDM B18C type R with hondata. I am wondering is there a difference between the P28 and P72 once it is chipped with hondata?
Old Nov 1, 2010 | 05:43 PM
canadaek's Avatar
Default Re: P28 or P72
no except obd
Old Nov 2, 2010 | 11:28 AM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
Pretty sure the P72 will look for the knock sensor while the p28 wont. Someone correct me if I'm wrong.
Also if you keep your stock IM the p72 will work your butterflies.
Edit: nvm, type Rs don't have butterflies
Did you mean P73 or are you running a GSR ecu?
Old Nov 2, 2010 | 11:54 AM
DA_PoWeR's Avatar
You are correct. I am running my gsr on a hondata p28 and even if you hook up the knock sensor you will still have a cel because the p28 does not have a knock board to look for a knock sensor.
^ and I am using a p28 on a skunk2 manifold. I am not using the oe gsr manifold.
Old Nov 2, 2010 | 02:33 PM
canadaek's Avatar
why would you have a cel light for a knock sensor when it dosn't look for one ? and if it's chipped you can remove sensor's so it wont look for them
MOVE OVER
Sep 6, 2007 08:59 AM
B2FiNiTY
May 5, 2005 04:33 AM
vtec92lude
Nov 2, 2004 08:26 PM
rocket256
Nov 29, 2003 08:16 PM
H22ek4
Feb 18, 2003 04:42 AM
