U.K H2B EK Civic
U.K H2B EK Civic
hi
here some pics and spec of my h2b civic, would like to thanks the guys on this forum for ideas, help and advise raidacaipo, NABeastRR, Seith QSD..
Car was built by Endless Horizion here in th UK
Its almost done just need a fresh cam cover and decent intake.
Few pics after a quick wash, sorry crappy fone shots
Here the full spec:
Engine:
• H22A7 2.2 Euro-R Engine
• ITR 98 Spec S80 4.7FD transmission
• QSD H2B Kit
• Hassport Billet Engine Mounts (B-Series)
• Kaizenspeed BS Eliminator Kit
• Competition Clutch Stage 4 - 6 puck sprung (B-Series)
• ACT Street Lite Flywheel 12.5 lbs (B-Series)
• Omini 70mm Throttle body
• KiddRACING H22 Tri-Y SSR Hytech Style Header
• Euro-R Crank Pulley (No P/S)
• Manual Tensioner Conversion
• P28 ECU chipped (Ectune)
• 3” Solid Fab Custom exhaust
• Aluminium Radiator and Slimline fan
Chassis:
• ITR DC2 5 Lug Conversion
• ITR DC2 Sub frame and Steering Rack (No P/S)
• EK9 1” Master Cylinder and Servo
• Miester Zeta R Coilovers
• Skunk2 Pro Front and Rear Camber Kit
• Skunk2 Pro Rear LCA’s
• ASR Rear Subframe Brace
• ITR DC2 Front and Rear Anti roll bar
• Braided Stainless brake lines
• Ebay upper Strut Brace
• Enkei RPF1s in Satin Black 16" 8J et38 with Hankook RS2’s 215/45/16
Exterior:
• EK9 Grill
• EK9 Yellow OEM Fog lights (carbon surround)
• EK9 Front Lip
• EK9 Rear Lip
• EK9 Folding mirrors with heated glass
• EK9 Rear lights
• EK9 Rear Number plate surround
• Crystal clear side Indicators
Interior:
• EK9 SRS Steering Wheel
• EK9 Centre console and Gear gaiter
• EK9 Hand break and Console
• EK9 Pedals
• EK9 Gear ****
• DC5/EK9 Custom rear seat
• Tinted
Modified Downpipe, much better clearnace and hugs oil pan
Video of how she sounds
May be bit diffrent style to over in the US
Thanks for looking, comments welcome
Here the full spec:
Engine:
• QSD H2B Kit
Chassis:
Exterior:
• EK9 Grill
• EK9 Front Lip
• EK9 Rear Lip
• EK9 Rear lights
Interior:
• EK9 Pedals
• EK9 Gear ****
• Tinted
Re: U.K H2B EK Civic
oh, yeh im still deciding to get type r wing or spoon duckbill wing
Very nice mate, im also in the uk, building an h22a5 which is nearly ready to go in my ek. Where did buy your ex mani from? Also your mid silencer and back box? Im looking to fab my own exhaust, what made you go for 3" rather than say 2.5"?
exhaust manifold is a kidd racing one bought from this forum, rest of exhaust was custom made by solid fabrications in london, i went 3" because it was recomended byt the shop that did my build, much more free flowing, less restrictive and freed up more power
My build will probably be pushing same sort of power as urs, h22a5 with 11.1 cr and crower stage 2's so im guessing 3" will be better for me too. Was the clearance real close before you modified that manifold? It looks a nice size, pipes look bigger than manifolds like japspeed and jperformance make
well it depends, if you going h2b your engine will sit tilting forward so any H22 header will need modifiying, this header was for h2b but still needed modifying, if its a straight H22 swap using H22 swap mounts then you engine will sit normal position so may not need to modify your header.
