92 civic lx sedan - How do I make a b18b1 swap work?
ok this is what i got i got a 92 honda civic lx 4 door i am doing a b18b1 swap on it what all do i have to do to make it work i got the motor ecu axels harness mounts everything is there anything i have to do to the wiring to make it work or just plug and play which im sure it wont be not my luck
Re: 1992 honda civic lx 4 door obd1
ok i put this up here cause i wanted to see what i was doing wrong lol but i got the motor in everything hooked up and it starts but for some reason with the p75 in it it redlines at 3 grand and its running bad
yea we made sure everything was hooked up right went through the harness more than a few times im going to try to putting my d series wiring harness on there i think there might be something wrong with the b series harness
Re: 92 civic lx sedan - How do I make a b18b1 swap work?
yea i have a check engine light i guess im going to have to buy a p28 chiped ecu cause it wont run with the p75 in it i have my stock ecu in it now with the d series harness in it
but i drove it back to my house to day it ran fine till i got just about home them went dead and i started it back up and now it redlines at 3 crand with my stock ecu in it now
like others said, check your grounds? also you can run it with stock ecu, i've ran mine with a p06 no problem, just didn't pull very hard
Seagull Management
Did you check to see what code is being thrown? If its not running with a stock P75 a chipped P28 isn't going to fix your problem, you could just chip the P06 DX EX anyway if you wanted something chipped.
no ill have to get someone to come and check it to see what codes its throwing and i have checked all the grounds none are loos or missing i dont knbow whats wrong with it
Seagull Management
here is the codes it is pulling 3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
14 IAC (EACV) - idle air control valve i rest it like it said to do and te only one im getting noe is the 3 MAP - manifold absolute pressure sensor
so im guessing the map sensor is bad or something is making it throw that code
Technical Hero
Check to see if you mixed up the MAP and TPS connector
Map Sensor
3 wires spaced left to right
White-Green-Yellow/green
TPS sensor
Yellow/White-Red/Blue-Green/White
Map Sensor
TPS sensor
Seagull Management
What engine harness did you use? '92 - '93 Civic DX/LX models have a firewall mounted MAP sensor , you have to unplug it and plug the connector into the MAP sensor on the top of the throttlebody.
ok ill tey that stuff and yes it had the map sensor on the fire wall but i was going to use the b18 harnes and inorder to use that harness u have to repin them but that harness what missing tomuch stuff it has hacked up so i used the d series harness and re pined it back to the plug
would it be pos. for my wires in the tps be back words cause urs saying left to right and me standing there looking at it the goes right to left
the tps and the map have the same plug but they are only long enough to hook to designated areas... i would say the reason y u have a iacv, and all the popping up is u didnt bleed the head correctly??? did u fill it with antifreze and crack the bleeder screW?? that will make it run high and like **** ...
follow top hose till it meets with block.. it should have a 12mm screw with a little nipple in the middle u cannot miss it...
fill er up with anti- freze put cap back on and let it get warm,
make sure u turn the heat on and all the way on high...
wait till the fan turns on and crack the bleeder screw, u will see antifreze coming out bubbling and once the bubbles dissapear and its coming out in a stream u should be fine
close screw and take er for a ride
