Where can I get a complete engine wiring harness?
I need the complete wiring harness from ecu to engine. I need the harness from any car that uses the P28 or from an OBD1 gsr. Thanks
Re: Where can I get a complete engine wiring harness? (slowasshatch)
got a civic one same as gsr unless your doin a gsr dash or something but if its only for the motor and stock civic dash this will work alrady has vtec pre wired and all you need to wire knock ill run the wire and tell you what pin 100$ for it shipped
Re: Where can I get a complete engine wiring harness? (sickaslewdpoweredatch)
Im runnin the P28 so I dont need the knock sensor. Im goin to check around locally first, but if I dont find one in a week Ill buy yours.
dpine
02-25-2005 04:15 PM
