How hard/easy is it to change an axle??
New User
Re: How hard/easy is it to change an axle?? (Type R106)
It takes me less than an hour with jackstands and air tools. Some of that time is just getting the car jacked up and finding the tools.
Former Moderator
Tools you'll need if doing a Civic or Integra:
19mm for the wheel
32mm big-*** socket and BIG rachet for it - to break off and tighten back up the axle nut
17mm wrench
17mm wrench again or rachet
Dykes
Hammer
Prybar
TRY to get the entire front of the vehicle off the ground so you can turn the wheels to make things easier.
1. Take the wheel off with the 19mm
2. Take the 32mm nut off the end of the axle
3. Take the dykes and pull the cotter pin out of the bottom 17mm castle nut on the lower balljoint
4. Take the 17mm and remove the castlenut from the lower balljoint
5. Take your big-*** hammer and whack right ON the lower control arm where the balljoint sits - this method for buting the balljoint out will not tear the balljoint boot like the "balljoint wedge" will
6. Take both 17mm and remove the thru-bolt that runs through the lower fork of the front stut - this will allow the axle to slide out when ready by pulling the strut fork to the side of the lower control arm
7. Pull the brake rotor out of the way - axle is ready to come out
8. Take the prybar and pry the axle by prying between the inner joint and the tranny housing
**CAUTION**
If it's a manual tranny you NEED to drain it if you're doing the PASSENGER side on a car with equal-length driveshafts - if it's a B-series this applies. Unequal length shafts will require yopu to ALWAYS drain the tranny.
Reassamble it how you disassembled it. Only then you need to stake the axle nut down by putting a dent in it and do'nt forget to replace the cotter pin in the lower balljoint castlenut!
19mm for the wheel
17mm wrench
Dykes
Hammer
Prybar
**CAUTION**
Re: How hard/easy is it to change an axle?? (therealciviczc)
Or check here: http://www.c-speedracing.com/howto/b18cswap/swap.html
Re: How hard/easy is it to change an axle?? (G3-TEG)
its not difficlut, just did one of mine.
just make sure you torque the 32mm bolt on the end of the axle.
C_Rock77
08-27-2008 11:19 AM
