GSR Pistons, Rods and Crank fit on LS Block???
Re: GSR Pistons, Rods and Crank fit on LS Block??? (pregunta)
Im not for sure. If the crank will go in then all three will go no problem. both blocks have the same deck height, so clearance wont be a problem. sorry i couldnt be of more help
yes, they all fit.
If you use a b18c crank, you have to use b18c rods.
pistonswill fit either way you go.
this has been covered before
Re: GSR Pistons, Rods and Crank fit on LS Block??? (sgT)
what about LS Crank and Rods into a gsr block? wouldn't that save a bit of trouble if you are building a Ls/Vtec?
Re: GSR Pistons, Rods and Crank fit on LS Block??? (GSRacer)
ok, cool good to know. so i should have no problems dropping in GSR internals + head into a GS block.
New User
Re: GSR Pistons, Rods and Crank fit on LS Block??? (civicdxtyper)
yeah, they are aftermaket pistons and rods. JE 9-1 81.5 mm, eagle rods and a fully serviced crank.
