LSD install???
Old Jan 19, 2002 | 10:11 PM
SPOON_BeIgHtEeNsEe's Avatar
Default LSD install???
ive been looking for a ITr tranny for the longest time and cant seem to find the right one... so im thinkin about just buying a gsr or b16 and throw a lsd in myself but i never takin apart a tranny yet... i was woundering if its easy or hard??? is there a place where i can find more information about how to install LSD??? and which lsd should i get??? i did a search but nothing came up... any help is ok... thanks
Old Jan 20, 2002 | 07:02 AM
rainforest's Avatar
Default Re: LSD install??? (00CiViC_SpecR)
its really easier than you think i did one for the first time like 2 months ago and was nicely surprised.
Old Jan 20, 2002 | 09:24 AM
bruthaboost's Avatar
I highly recommend the helms. It's easily the best 60 bucks I've blown on my ride. It'll tell you everything you need to know. I also highly encourage you to try this yourself. I had a shop do mine ('cause I was lazy) and ended up having to crack the casing open cause they used the wrong sealant. Use the Permatex ultra grey.
While the case is open shift through the gears and you'll get a very good understanding on how the tranny works and all the talk about short shifters ruining trannies is bunk.
Also it helps to have another set of hands around when putting the case back over the gears. The set ring which keeps the casing "on" is a major PITA. And for some strange reason the case would only drop on when the tranny was in 3 gear. This also happened to Type-C.
hth
[Modified by b18bpwr, 10:24 AM 1/20/2002]
Old Jan 20, 2002 | 09:55 AM
1 2 NV's Avatar
i went to hybrid honda and found article on installing the JDM final drive. well its the exact same process and throwing in a LSD. i agree with the other guys though. if ur halfway handy with some sockets do it urself. i never even seen the inside of a tranny b4 when i did mine. what a piece of cake. the only thing i didnt do was press on the bearings, i had the tranny shop do that. cost me a whole whoppin $20. as far as sealant, my honda service manual says that u dont need it, i would highly disagree. i used permatex gray also. go find that article, its step by step in words. pretty easy. good luck. 1 more thing. y not just buy a ITR tranny???? a b16 or GSR tranny will cost 600 or so and then the LSD will cost another 800+. just buy a ITR tranny for 1200 or so.
[Modified by hondaatwsu, 10:56 AM 1/20/2002]
Old May 22, 2005 | 02:56 PM
rocket_R's Avatar
Default Re: LSD install??? (1 2 NV)
how you guys take off the speedometer gear off??? h22 with quaife
Old May 24, 2005 | 09:25 PM
skunkwhat's Avatar
Default Re: LSD install??? (rocket_R)
i used a punch to take mine off.
Hobkins
Transmission & Drivetrain
37
Apr 20, 2009 03:42 PM
Soon_2b_evil
Jul 17, 2004 11:28 AM
playAho
20
Sep 13, 2003 05:59 AM
USDMMARK
Apr 25, 2003 04:55 PM
dalecrx
Mar 6, 2003 06:38 AM
