90 LS Trans: Will a GSR clutch work??
Ok guys, well the topic pretty much sums up the question. I have a 90 LS trans and want to upgrade the clutch. Now I know that sometimes you can upgrade your stock clutch with a stock clutch from a stronger motor, thus giving you a beefier clutch. Now which clutch can I use on this trans? Will a GSR or Type-R fit, and if so which year?? Thanks guys.
Re: 90 LS Trans: Will a GSR clutch work?? (VTECHatch)
Help!!! I just got an 1991 b16 (cable type) from the importers and they said that they would supply a tranny later. The tranny they supplied is cable, bolts up but the input shaft is to big for the clutch plate. How many different input sizes are there in cable B16 boxes and what clutch do I need?
170 hp + 1850 lbs =
170 hp + 1850 lbs =
Re: 90 LS Trans: Will a GSR clutch work?? (b16a4me)
theres 2 different sizes.
the 90-91 used the smaller size same as 90-91 integra here.
92+ all use the same size. so if its too large now you will need a 92+ integra
clutch disc.
clutch disc.
