distributor question
Old Jan 13, 2002 | 02:12 PM
boot machine 5000's Avatar
Default distributor question
i have a first gen b16a thats going to go in my '00 ek. i know that i have to convert convert everything to obd1. i'm looking for a gsr or ls distributor, does it matter what year ditributor i get? any info on this swap would help, thanks in advance
Old Jan 13, 2002 | 07:40 PM
SpeedracerS4's Avatar
Default Re: distributor question (ALVIN)
if you have a 00 EK you need an OBD 2 distributor not an OBD 1. So any distributor out from any DOHC vtec motor yr 96-01 will work. You can use a LS distributor also but a minor mod must be perform.
Old Jan 14, 2002 | 04:13 PM
Default Re: distributor question (SpeedracerS4)
how can i tell a difference from the two distributors obd1 and 2
Old Jan 14, 2002 | 09:32 PM
B_CRUZ!'s Avatar
im not sure but i think OBD2 dist. has 1 plug and OBD1 dist. has 2. (correct me if i'm wrong) but in any case get a gs-r one so you don't have to modify the ls one by chopping off a leg.
white92teg
Apr 12, 2010 08:03 PM
wwcrxww
Sep 28, 2008 09:52 AM
VTECth1s
Jun 5, 2006 04:09 PM
egvtec
Aug 10, 2004 10:25 AM
20lb.teg
Feb 6, 2003 05:30 AM
