which mounts for ls/vtec?
Old Jan 20, 2002 | 01:13 PM
98 Ek LsVtec's Avatar
Banned
Default which mounts for ls/vtec?
ok so i finally bought a oil pan to fit w/ the z10 girdle and got my plugs and wires now all i got to do is put all that on the motor not to mention bolt up the tranny,but my question is what mounts do i need the motor is ls/vtec it's a 00 block and a 97 gs-r head and gs-r tranny (don't know if yall needed that info or not but there it is)i bought the 99-00 si motor mount and i was told i can use the rest of the stock mounts is this true?
i almost forgot i got a 98 civic coupe ex
[Modified by 98 Ek LsVtec, 2:14 PM 1/20/2002]
Old Jan 20, 2002 | 03:53 PM
jgale's Avatar
Default Re: which mounts for ls/vtec? (98 Ek LsVtec)
use the '99 Si rear mount, your stock driver's side mount, and the rest from the motor you bought. If running a/c, I think you need the Del Sol a/c bracket/mount. Not sure though. Someone verify if this is correct?
Old Jan 20, 2002 | 05:54 PM
Jackson's Avatar
99-00 si rear mount. stock civic drivers side mount, stock civic upper tranny mount. 94-01 integra front tranny mount and a/c mount. if you are using a/c, there is a mount that will fit, but a debate on which one it is. i have heard del sol vtec and others. i just ripped the a/c out.
Old Jan 20, 2002 | 06:29 PM
Banned
Default Re: which mounts for ls/vtec? (Jackson)
thanks alot guys
projectpd
May 14, 2007 10:30 AM
b17turbo
15
Jun 7, 2006 02:33 PM
EJCivJdM93
Feb 9, 2005 04:40 AM
jcivic
Feb 11, 2003 07:56 PM
sirIIchadwick
Dec 13, 2002 07:09 AM
