B20B rod ratios
Old Jan 13, 2002 | 09:18 PM
FreeMyndz v.FP's Avatar
Default B20B rod ratios
OK, I have been hearing that when some people do a B20VTEC that they change out the CRV crank for a B17 crank...I know it will work but don't you lose torque(the whole reason to go B20) with the shorter stroke???
Old Jan 14, 2002 | 12:19 AM
Spoon_Civic's Avatar
Default Re: B20B rod ratios (FreeMyndz)
Using the stock bore of 84mm:
The B17a crank in the B20b block gives you: 1804 cc's.
cheers,
http://hcoc.2u.com.my
Old Jan 15, 2002 | 05:26 PM
daver's Avatar
yes you lose torque, by having the higher rs ratio setup, but it would more conducive to high revving (to tap the vtec potential). Kind of a compromise i guess, between the two mutually exclusive setups. You'd have to get custome length rods tho, and the crank itself is like a grand. It talks about it on crvtec.com
d
vtec_racer_2kgsr
Nov 19, 2003 07:36 PM
Andre
Oct 29, 2003 03:45 AM
DAYUIZ
Jan 14, 2003 12:21 AM
FreeMyndz v.FP
Jan 14, 2002 04:05 AM
XSBoost
Jun 12, 2001 10:46 AM
