Distrubutor for b16, can any others work.
New User
Re: Distrubutor for b16, can any others work. (futuresi)
gsr or a modified ls will work just fine. to get an ls to fit properly you need to hack off one of the 'legs'
Re: Distrubutor for b16, can any others work. (bojangs)
Well the problem is that I hear a grinding sound coming from it...would I have to replace the whole thing or just buy a part and slap it in?
If you take the rotor and dust shield off, you'll see the main bearing. Check that for play. Also, check that none of the sensors have come loose and are hitting the triggers.
mikegeezy
10-20-2008 06:15 PM
