JDM B16 1st G Header
Any one has pictures of primaries and B pipe? Need to know the exact O2 locations on primaries and secondaries.
TIA
TIA
New User
Re: JDM B16 1st G Header (Lyonel)
It sucks having the jdm engione cause to get a header you got to find one you like the weld in the second O2 sensor, damn I am think of getting an ITR header but I don't want to cut the header, anyone knwo a way around this?
Re: Thanks (Lyonel) and..
So, the O2 sensor with the green plug sniffs 3 and 4 cylinders and the one with white plug sniffs 1 and 2?
MOreover, which O2 sensor is Number 1?
TIA
TIA
New User
Re: JDM B16 1st G Header (Hanson)
The o2 sensor that is higher up on the header is the number one o2 sensor and it reads cylinders one and three, the lower one reads cyliders 2 and 4. I tried to slpice the wires together and it threw up o2 sensor ecu errors, but I have them wired right now and it runs just fine
Re: JDM B16 1st G Header (91sifreak)
Just to confirm, the higher up is the one with the green plug, right? Very slight difference on teh picture.
TIA
TIA
91sifreak - I spliced my o2 sensor wires together when I installed my JDM ITR 4-1. No codes... just takes a while for the o2 sensor to heat up.
Correction
the O2 with green plug reads 1 and 4 cylinders.
The O2 with white plug reads 2 and 3 cylinders.
The green plug goes to the USDM existing O2 plug. The extra one is the white one!
MainStreamHonda
08-09-2011 09:36 AM
