ecu threw code 43
Old Jan 20, 2002 | 02:39 PM
nutsack's Avatar
Default ecu threw code 43
43 - Fuel Supply System defective or malfunctioning fuel supply system
does this mean the civic fuel pump is not enough for the GSR motor?
Old Jan 20, 2002 | 06:36 PM
TurboBumblBee's Avatar
Default Re: ecu threw code 43 (*******)
not sure but it could be your gas cap.. take it off and put it back on again making sure it makes 3 clicks.. this
Old Jan 20, 2002 | 06:51 PM
ekb18c's Avatar
your pump may be bad, code 43 has nothign to do with the gas cap. lol
Old Jan 20, 2002 | 09:28 PM
grippgoat's Avatar
Well, on my NSX (OBD-1), code 42 is rear fuel supply system, and code 43 is front fuel supply system. According to my mechanic, it's almost always an O2 sensor (on all Honda/Acura). When my NSX threw a code 42, replacing the rear O2 sensor fixed it right up. My NSX is now currently throwing code 43 and code 01 (front fuel supply, and front O2 sensor).
I'd go for the new O2 sensor. I'm pretty sure it'd fix your problem, and you'll probably get better mileage if it does. When I replaced the bad rear O2 sensor, my mileage improved from about 18mpg to about 22mpg.
If your car is OBD2, I'm not sure what to tell you, as I don't know which O2 sensor it would be.
Lastly, if you have a factory service manual, there SHOULD be debugging info for that code.
-Mike
Old Jan 20, 2002 | 11:06 PM
nutsack's Avatar
Default Re: ecu threw code 43 (grippgoat)
thanks for the info.. my setup is ODB1, so maybe it is the o2 sensor.. the code usually pops up when i'm just cruising at constant rpm and partial throttle...
Old Jan 20, 2002 | 11:09 PM
grippgoat's Avatar
Exactly the same conditions under which my car throws the code. More prone to happening up hill, as well (doesn't often happen on flat ground, I think it's because my engine has enough torque that I can't keep a constant speed while still maintaining a medium throttle setting).
I'd definitely do the O2 sensor.
-Mike
Old Jan 21, 2002 | 09:41 AM
markpaco's Avatar
Me too. I replaced all of the fuel system components (rail, injectors, filter, etc) and it didn't work. I decided to change the O2 in desperation and it worked. 2 weeks later I swapped out the motor for a B18C1 anyway. And I kept the O2 sensor when I gave the wrecking yard my core. heh.
dejay2014
Aug 24, 2014 09:16 PM
91ef_ls
Nov 15, 2006 06:15 AM
PhilStubbs
Jan 22, 2005 11:20 AM
JSPECHB
May 3, 2004 04:52 PM
95civicracer
Nov 21, 2003 10:29 AM
